That does indeed look like a signal tracer. However, note that it says right on the carton that it is "transistorized". I do not recommend that for any serious troubleshooting applications for all the reasons I mentioned above however.
For those wondering why these signal tracer testers back in the day all used vacumm tubes instead of transistors.... check out this comparo
http://www.effectrode.com/signal-tubes/vacuum-tubes-and-transistors-compared/
An ideal modern signal tracer would be one that incorporates operational amplifiers to produce the reproduced audio, automatic output level adjustment so the audio would always be at a comfortable listening level for you to discern the "quality" of the audio signal being tested (does it have hum or distortion?), and also include a gain level meter to show how much amplifier gain was necessary to produce the output result (so you can tell at a glance whether the signal amplitude being tested matches the expected output level for the circuit being tested).
maybe I'll have to make one? A smart device using an arduino comes to mind.
