M70 & M90 with hardwired bluetooth module mod.
trippy1313
Wow you're on it! You do all that and upload in the matter of an hour??? With kids in the house?
I need a hands down bow emoticon. My phone browser won't do it.
SLO
:bow: :cool:
Thanks guys. Hopefully the BT module will be here early next week. I still need to patch up my spare front case and paint it.
I might go custom with this color.....
Finished transplanting the guts.
Shined up the switches, rings, and plexi.
Fresh paint on the grills.
I also decided to fix the cracks on this case because the front is so mint. I will only have to paint the sides. Someone tried gluing the crack at the bottom and it made the crack fit together like crud. I had to scrape and sand the glue out before using acrylic cement.
So awesome that this new BT module showed up already. Even better that this one is in a hard plastic case so I was able to open it and check out the goodies!!!!
It looks like the BT module chip is piggy-backed to the voltage regulator board so you can pump 12v into it direct instead of the 3v-5v the module needs.
$30 on this one from Amazon.
I will give a full review/test of it later tonight. I won't know the range until it is in the boombox and finished. Maybe I can buy in bulk to offer the modules here for cheaper.
EDIT, WTF - the company already bumped the price from $30 shipped to $35 shipped!!!!!
:bang: :nonono: :thumbsdown:
Well, sounds like you got a good deal
Some progress.
This new BT module doesn't make any sound when you turn it on. That was a great feature on the last box. So I added blue LEDs that will light the VUs when the BT is on.
I also desoldered the REC/MUTE switch and used the board and metal bracket and soldered a new switch in its place. Lines up better with the top plate hole for the button.
I just need to figure out why the M70 doesn't power on until I use a cassette function. And sand the side panel and repaint that small area.
trippy1313
So where did you get a switch for this one? I know the first was almost a direct replacement with a 922 I think you said. How but this one?
The 922 had 3 switches that were perfect. 1 I used for my discolite power switch and the last 2 went into the M70s. I will buy one of the ebay switches and review it on the next BT M70 in my collection that I will keep.
It all started with you man. I wouldn't have even tried using a rechargeable BT dongle.
Ever since then I have wanted a better option. My courage to try this on a popular box finally got to me and off I went.
I'm glad the technology has advanced to a level that I like.
Now, I ordered a 3rd style of BT module today. I will be getting a small stock of switches (because I have 4 M70's I still want to BT).
I can't wait to test, review, and compare the 3. I already see huge differences in the first 2.
The first 2 BT M70's were bought to install, test, and sell.
After I decide what BT module I like best, then I will start to BT a lot of my blasters INCLUDING the OG TDK 2 speaker, JVC M90, JVC M71, and a handful of others.
