i would choose the big ben over the 920 any day Reli. the only good thing about the 920 is those stunning looks
Yea it sounds like a mini home system. Very powerful bass. The bass is phenomenal and so clean and goes deep. If u add the SpotEQ app on your phone and adjust the 30hz to max and all other frequencies about 80% lower, this box turns into a bass monster!Ghettoman said:I have always liked the bass and highs from the Panasonic DT680, the bass is lovely and the treble is also nice, but like a lot of other boxes, its not the loudest..
Best sounding Sanyo, IMOSel The Don said:I've never listened to a Big Ben, would love to have a listen to it.
What are the best replacement speakers for sharp 777?If you really want to go for the Gusto get a good G f-777 and replace the speakers with modern ones this combination will absolutely f****** destroy any of the other boxes.
The GF 777 is a very powerful Boombox with shity speakers.
This box has a very strong amplifier for the two middle speakers which you can use 4 ohm 6.5 inch subwoofers or a component speaker woofer 4 ohm . You can also use 4 ohm 6.5 in car speakers coaxials for the outer set of woofers. Really any decent brand of car speaker will get the job done.What are the best replacement speakers for sharp 777?
And the tweeters? Already swapped the full range drivers. Thank youThis box has a very strong amplifier for the two middle speakers which you can use 4 ohm 6.5 inch subwoofers or a component speaker woofer 4 ohm . You can also use 4 ohm 6.5 in car speakers coaxials for the outer set of woofers. Really any decent brand of car speaker will get the job done.
