-GZ-
That's what I meantredbenjoe said:right --the handle is prolly fine --
its the mounting set-up that may need some beef
i agree , i'm tired of freezing . you can get 10x more done on one nice day without the misery.JustCruisin said:Just waiting on warmer weather to do the filler work, this below zero stuff is gettin old..![]()
What are you using to weld the parts together?JustCruisin said:first day above 0 degrees and get snowed in, so had time to work on it again!
Finished welding in the vents, now I just need to fit it together nicely then I can get started on the fiberglass finish work..image.jpg![]()
Sometimes, if you want to do something right, you've got to do it yourself.JustCruisin said:To anyone thinking of doing something like this, I would advise against it.. It's a LOT of planning.. Both in the mind and on the workbench.. I'm just glad the idea I had in my head is coming to life! The other reason I'm doing this is after countless hours of searching eBay for a cool blaster and coming up empty-handed, I decided to build my own!
