Regarding my 3-speaker issue: I bought this unit second-hand, so I have no idea what its brand-new condition should be.
The problems are as follows:
- When the device is running and playing audio via USB or radio, even if the volume knob is turned to the minimum position, the sound is still very loud — louder than a person speaking at a normal volume. If you turn the volume knob slightly higher, the sound becomes extremely loud, to the point that it feels unbearable for the ears, so I never dared to turn it up further.
- When I play audio through the line input, the sound can be fully muted when the volume knob is at the minimum position. As I turn the knob up, the volume increases gradually. However, once the knob is rotated to roughly a quarter of its total travel, further turning of the volume adjustment knob no longer makes the volume any louder.
I'm not sure if there's a problem with the device's volume potentiometer. I'd like to ask everyone: under brand-new factory conditions, can the unit fully mute the sound when playing via USB or radio? Is this issue caused by a faulty volume potentiometer, or is it due to some other malfunction? I would appreciate your guidance.
If it can be confirmed that the problem lies with the volume potentiometer, I plan to try replacing it. But I haven't removed the volume knob yet, so I don't know the exact model of the 3-speaker's volume potentiometer, nor whether I can find a potentiometer with a built-in switch. So far, I've seen in this thread that the 2-speaker model uses a B503 potentiometer, but I've tried searching and haven't found this model with a switch.
Additionally, I found the teardown photos provided by blu_fuz in this post extremely helpful, and I'm very grateful for that. I had an idea: since a full teardown is quite troublesome, and the Boombox has a large inner cavity that appears mostly empty with few obstructions on the upper left side, if I only need to replace the volume potentiometer, could I just remove the left speaker, reach into the Boombox's inner cavity through the speaker mounting hole, use a screwdriver to remove the PCB board screws, and take the volume potentiometer and PCB board out through the speaker opening? This would save a lot of effort. As for not being able to see the screws clearly, I can insert a camera with a light into the inner cavity, connect it to a monitor for a live feed, and perform the screw removal that way.
