I have the Cube (non-wireless version). There is power but no sound after several years of stellar performance. Does anyone know a fix?
Thanks!
Thanks!
I remember that video of the C100 on YouTube.riker1068 said:I would have smashed it and took a video of it on fire!
TDK designed a contingency for that, you didn't have to tear it apart to un-brick it.
I had a flash update go bad, and had to go through this procedure, but it works.
https://vowe.net/archives/012911.html
The volume pots on the TDK are tricky to deal with.....
good luck.
Hi there, thanks for sharing the photo's.
My TDK Boombox 3 does not turn on. I just pulled of the Power 'button' and saw one of the wires is loose.
Any idea how to fix this? I do not have a lot of equipment...
I tried if it would turn on if I would just put the cable in the right position, but that is not the case... I think it is still not really connected then.
She says it lacks deep bass? She's either on drugs, or wasn't using good source material. I tested it against the 3-speaker, and it has better deep bass than the 3-speaker. I think it's because the 2-speaker has a bass port and the 3-speaker doesn't. They did a good job tuning that port to produce low bass. It's a great box for 90s/00s hiphop.Review
Worth It?: A Modern-Day Boombox
Boomboxes trying to make a comeback - with a higher price tag and high-tech profile. WSJ's Willa Planks takes one boombox to the streets to see if they're still cool.www.wsj.com
So sorry I missed this when you posted it.Unfortunately, it looks like I have the same problem with my TDK, do you still have a software update file somewhere? He is not on the manufacturer's website anymore ... I will be grateful for your help
Maybe you can try and see if you can get this to work for you. Some modification or fabrication might be necessary -- it's unlikely to be able to find an exact copy of the original.I know its a pretty dead thread but I just picked up one of these and it works but needs a new pot. I've found out the "B503" marking indicates a 50kΩ linear taper potentiometer but after spending some time looking on Mouser I'm having trouble finding a replacement that also has a switch built into it as well I'm sure one can be sourced but there is so many variables when looking up very specific electronic parts perhaps someone knows more what to look for since I know the specs of the pot?
Thanks!
