Joe:
I've been going back forth on some of these measurements and flipping back/forth between your readings and the diagram, I might get lost and so these recommendations are somewhat random. Anyhow, rather than 15 back/forth step by steps, I'm going to trust you to do a little diagnostics along the way with some guidance.
Q411: Base leg needs .7 volts to be switched ON. Until it's switched on, the voltage at Q108/Q208/Q408 will be wrong. You need to follow the diagram (use schematic) and find out why you aren't getting at least some voltage. D103/D203 is getting .7volts and it's also tethered to (a) jumper (like Q411) so you'll have to figure out where the issue is. Also make absolutely sure that you did not accidently ground that circuit when you made all those jumper bridges (in case they were jumped wrong).
Q109, Q209, Q407: I believe all of these transistors are not turning on due to an issue with the circuit feeding it. Follow along with me.... You said previously that Q206-C is getting ~7.5v, right? This is about right. Now from there, follow the circuit through this path:
Q206-C --> R441 --> (S3-4 pin 4) --> (S3-4 pin 1) --> (S2-12 pin2) --> (S2-12 pin1) --> R468 --> [C jumper]
From [C-jumper], the circuit goes through R458 to Q407-B and also from [C-jumper], goes through R465 to Q109/Q209. None of these transistors are getting voltage at the base, but since you are getting 7.5v at C-Q206, there obviously is a break somewhere. You need to follow and find the break.
IC403: I don't have an internal block diagram so can't comment on the innards and any effect it would have on those pins. However, it looks to me like R420 is toast. I would cut the trace to R420 to take it out of circuit, then tack a discrete 4.7k resistor between pins 4-6 or 4-8, whichever is easier, from the foil side. Also, if the trace area around R420 shows any sign of corossion, you should check continuity between all.
One comment of note: Please use correct language when expressing measurements. NO RESULT is NOT proper way of expressing measurements and leads to misunderstandings and confusion. Does no result mean "0"? Or does it mean infinity? I am presuming you mean infinity. However, you should always express such readings as infinity or OC (open circuit). 0 is 0, 100 is 100 and infinity is OC, but no-result means whatever the person interpreting it means. In other words, when taking a measurement, there is ALWAYS A RESULT.
