Norm1968
Hi
Soon will be listening to a Sony CFS-500... same as the one I had bought bran new in 1982
Nickeccles
This was recorded on this machine via bluetooth module direct to line in & it shows there's life in the cassette format yet
Slight sibilance on the video due to my Samsung S7 Edge & it's audio limiter - there is no such sound in reality.........
Bargain of the year so far & a cassette deck worthy of HiFi status
Love it!!
A fine Irish folk/pop tune playing away!!
https://youtu.be/bzVdJUwK_kQ
T-STER
Hell yeah, they sound great don't they? Funkadelic on a Big Ben really brings out that funky bass to. Beauty's.
OK, time to cut the **** and go big and bassy with the DIY V5.0 for some outdoor home maintenance fun. :rock:
Heat gun stripping the timber floor of my front verandah - hours and hours of fun. :lol:
Safety first! :-)IMG_4579.JPG
jimmyjimmy19702010 said:
OK, time to cut the shiat and go big and bassy with the DIY V5.0 for some outdoor home maintenance fun. :rock:
Safety first! :-)
Lots of bending and lifting involved, wear lower back support safety belts! It is not easy to work on floors! I have a 100+ Lbs German shepherd who pulls me and mess up my back. Now my back got stronger!
mellymelsr
Giving my latest creation a good run. Conion C100FF painted White Diamond Pearl. It still has a few finishing touches left to add...waiting on a chrome trim kit. The paint color is stunning in person.
Barb Bush
Looks like something the Empire would own. Might be standard issue for a Storm Trooper.
Don't ask HipHop Trooper. He wouldn't know.
[not my photo]
mellymelsr
Spray cans with custom nozzles. Dealer paint so the quality of paint is excellent. This C100 has 5 coats of pearl and 5 coats of clear. I also use polishing compound after paint cures for a silky smooth finish.
[not my photo]
"Hokey religions and ancient weapons are no match for a good blaster at your side, kid.
riker1068
Can you share the dealer brand and special nozzle used? I been wanting to white out 1 of my 777s
mellymelsr
Duplicolor color match car paint. The cans come with adjustible nozzles to customize your spray patterns. It helps to know which pattern works best at a particular angle. Distance, nozxle pressure, ambient temperature, and humidity all affect paint results. I paint in a tempetature controlled, dust free, moisture free environment. The most important component is the prep. Good luck and happy painting.
