My next victim of RGB slaughter....
Cpl-Chronic
SLO said:
Wow I cant even see the speakers on my M80 through the waffles, what color did you paint em??? Looks great :yes:
Yeah, when the LED system is off, you can't see the woofers at all, except in very bright light & at the right angle....it's pretty cool.....
Cpl
Cpl-Chronic
Northerner
Cpl-Chronic said:
Ok, a taste of things to come for the M80...I have to think up a good name for it too....
I want to thank Northerner for inspiring part of the mod shown above with his waffle grill LED mod. He posted a thread & I thought it looked great & wanted to do something similar but with a full RGB system for more punch....
stay tuned....
Cpl
Thanks mate. Looks great! :-)
Cpl-Chronic
Grrrrr.....I Hate waiting for parts & supplies......
In the meantime, I think I have a general scheme in mind for the LEDs....the real trick is what kind of room do I have to install the controllers....The M70 & 80 are actually quite cramped but JVC usually incorporates about a half inch of clearance between the chassis & cabinet walls....genius engineers, they were at JVC.....the best...IMHO...the M80 is it's own challenge tho....no tuner window to light this time & space is very limited overall....
Now, it's time to set up the LEDs on the body & speakers & then wait for my fan cable extenders to come in....I'm waiting on the 3-pin connectors from China to come in any day now so I can wire up the sensitivity knob & remote 'eye' on the body of the blaster...
Cpl
Cpl-Chronic
Ok, so here's some pics of the first dry run for the waffle leds.....
Now I have to map out how if possible, I'm gonna light up the tweeters, tape bay, etc...hopefully a full plan will come together by tonight. Once I have the plan in mind, it's time to hammer those LEDs into the various spots on the cab & wait for my wiring to arrive...
Cpl
Cpl-Chronic
Ok, here's how I did it:
Tape & measure - first step
Drill holes and hone out the sides with the bit...
File & finish with a small diamond file....hardly noticeable unless looking straight on....or lit....
BAM!!
Cpl-Chronic
Thanx SA, Floyd :-D ....yeah, the 80 is gonna be a bit hectic, fitting the extra cables, controller(s) & LEDs inside but it looks doable & the waffle LEDs are coming out good.....with the M50 woofers, basically a 6.5" version of the M90 woofer, it'll pound it out quite nicely I think....gonna shoot for 1 controller & then see where it goes from there....
wish me luck,
Cpl :w00t: :bang:
hell i love the m50 woofers swap prolly sounds better now. one of the most unique jvc's and over looked boombox model's . i think this is a great build the m80 deserves some respect .
trippy1313
By the way, you can have the name "Project Dyn-o-mite" I hold no rights to it. Lol.
Looking good Cpl. Those waffles are perfect for hiding them!
Cpl-Chronic
Ok, now the corner LED holes are drilled & finished
Now I've got to get prepped to secure the leds & center them in the holes I made. After that, finalize the woofer LED placement & epoxy them in to eliminate rattles, etc.....
Stay tuned....should be done in about 4-5 weeks, unfortunately, due to supplies....waiting is the worst when you're 3/4 done.....
Cpl
Cpl-Chronic
Oh, yeah, I decided that the name for this mod is going to be another Godzilla Monster in the true DISCO Chronic tradition to be announced later....
Cpl
Cpl-Chronic
blu_fuz said:
So many places to hide LEDs!
Actually, because of the design, the space is pretty limited as to where I can put them on the front....will definitely be a toned down version of my usual madness....still waiting on fan connector cables for my interconnects....
Cpl
