I still have to paint the chrome trim around the tweeters, now that the black is finished & the grills are painted. I'm working in the paint on the woofers.
The secret, when painting woofers is 2 thin coats. As soon as the first coat tacks, apply the finish coat, lightly. let the woofers dry 12-24 hours, depending on the type of paint, let them dry while resting with the cones facing up & sitting on the magnets. This allows the paint to flow evenly. Once it has mostly dried, but not yet 'hardened'(12-24hrs), install the speakers & put some good bass through them for the next 2-3 days & as much as possible. That way, while the paint does its final hardening the ribs of the surround won't get too stiff. This helps the speaker's suspension stay efficient. If the ribs of the surround harden or stiffen, bass response & SPL will suffer.
Once, you paint it, wait a day, then USE it or LOSE it.
Cpl
Cpl
