Wish I still had mine apart as I was working on deck last week. I am getting an M90 for restoration tomorrow and will work on this weekend. I'm wondering if solenoid has issue
Bad Boy Bill
Bad Boy Bill
Plunger in the solenoid is pulled in by current passing around magnets creating a magnetic field making the plunger pull in ( energized state ). when current is removed the solenoid goes into its normal de-energized state. The direction of the plunger spring tension is the normal de-enerized state/position. When the solenoid is energized it compresses the plunger spring and pulls the plunger in and is in the energized state/position.docs said:Not sure what is is that pulls the solenoid in or what specific action or situation. Thing that makes me wonder is that when the solenoid is in the deck does not seem to be operational.
When all powered up and not touching anything, the solenoid does not get pulled in, it barely moves at all.baddboybill said:So while deck is hooked up and powered up can you see the solenoid and what it's doing without tab pushed in? And what does it do when you hold in solenoid?
Bad Boy Bill
docs said:....nor do any of the buttons work.....
BoomboxLover48 said:Glad to hear all is fine....
After replacing above diode with above link, the deck seems to now do a cyclic check on power up. Upon placing a cassette into the mechanism it seems to try to auto play but only getting half way. On moving the flywheel manually it begins to play. Pressing stop does stop the tape playing but it then tries to auto play again thus leaving the buttons inoperable while it is in this weird inbetween stage. Getting there but seems there are more faults with this !docs said:Discovered D705 is bad. It is a 1S2076 according to the service manual.
Is this a 35v standard diode ? Would anyone be able to assist please as I would like to buy a suitable replacement.
How about this?
