Q; First, you wrote something about a tuner knob base that was broken? My tuner knobs seems wiggly, too so I really suspect it to be the same problem you had. How is this fixable?
A; Some of the plastic had to be epoxied back in place that stabilize the knob. has to be done from inside.
Q; Second, the spare knob you put on for mic mixing - is it a Lasonic one from their page? Or did you get it from a member here...because I am afraif of getting the wrong knob on the Lasonic website
A; Replacement knob I got was not from website but it was wrong one and had it to be modded to work. The knob I received was not a d shaft knob
So I cut that shaft off and epoxied an appropriate one in place of the one it had.
Q; Then...removing the knobs is no biggie...can you remove the tuner button by just pulling it off? Can you remove the function knobs by just pulling them off?
A; I could not get my tuner knob to come off so I left it in place fearing I would break it off all together. The rest came off very easily
Q; And how did you remove the decals?
A; Very easy they just peel off.
Q; Oh...and can you just remove the cassette keys easily?
A; I didn't take the cassette keys of as I had no need to do so.
Q; The chrome rings on the speakers can be removed from the inside?
A; Yes
I will also need to take out one of the speakers on mine because something rattles and I strongly suspect the chrome cap to be loose.
You restoration job on this one looks absolutely outstanding by the way! I would be happy if I got mine to look only half as good
Thanks Max hope I answered all your questions well enough.
also Thanks Freddie for the compliments
