Yep, it's great stuff. You've just got to be a little careful with the jig saw when cutting to avoid chipping. MDF is easier to work with but it's almost twice the weight!JVC Floyd said:that plywood is the way to go , i started building my sub boxes from birch plywood and let me tell you it's much lighter than mdf and stronger too!.
For static indoor applications, I agree MDF is a good choice as it's the denser (quieter) material.Cpl-Chronic said:The reason MDF is used is because it has the least amount of coloration or'box' sound of any other material. I use MDF & ONLY MDF for a good reason. Plywood is a good 2nd to MDF. 1" MDF is best for sound quality especially for large woofer or sub-woofer systems...
Cpl
Thanks for the tips Jimmy.jimmyjimmy19702010 said:Those clamps do come in handy!
I'm looking forward to seeing that 3 piece combo of yours in action!
I would advise against MDF if you plan on making your project portable. It's super heavy, can't cope with moisture and isn't structural strong enough IMHO.
If you have already made your cabinet, make sure you use long screws after pre-drilling the holes on all joints!!
James....![]()
Wow, your box is huge!! Are you going to make it portable with a battery?hardmen said:Thanks for the tips Jimmy.
I'm use MDF only in the structure cabinet, no screws at this time, only glue.
Some pics below.
My Clamps (LOL)
CAM00675.jpg![]()
The structure (6mm MDF and some pinus pieces to help on corner joints).
I' m not have precise cut tools on home, so I paid $10 for the all MDF pieces cutted.
CAM00676.jpg![]()
CAM00678.jpg![]()
CAM00679.jpg![]()
Cheers.
The size is similar as Panasonic RX 5350 and YES, I will make it portable (maybe 7 or,12A lead acid one).jimmyjimmy19702010 said:Wow, your box is huge!! Are you going to make it portable with a battery?
Good idea getting your pieces cut ready for assembly.
James...![]()
I'll be firing up my new router so I can have nice, curved edges on this box.
Thanks Fuz,blu_fuz said:Nice clean corners and the pieces fit really well.
