Jambox_72209
A couple of things I noticed about the D8443 and an anecdotal report:
1)The pathetic little piezo tweeters are wired to the 8 ohm speakers in parallel. From what I understand, wiring in parallel drops the overall impedance per this formula: multiplication of the two loads divided by the sum of the two loads - i.e. putting two 8 ohm speakers in Parallel results in a 4 ohm load. In this case, those Piezos are likely high impedance but still lower the overall impedance of the total load at least a bit.
2) The amp section has what appears to be a decent sized heat sink, but services two chips and is just a smooth metal bracket with no fins. Is that good enough?
Just last night I put a pair of 5.25" Skar 4 ohm coaxial speakers in my D8443 and scrapped the piezos. So far, these car stereo speakers run like a champ, with a punchier, more modern sound, crisper highs and much improved bass and treble response over the originals ...and somewhat less distortion. In fact the original 8' woofer that remains can't keep up--it distorts at high volume and I am considering putting a switch or pot on it to remove or attenuate it in the mix to clean up the sound.
I can feel a very slight warmth to the rear cover behind the amp, and that is after several hours at moderate volume.
Not too bad so far.
Not too bad so far.
RPX525 | 5.25" 150 Watt Coaxial Car Speakers - Pair | Skar Audio
The Skar Audio RPX525 2-way 150 watt coaxial car speaker set was designed to be price sensitive while also delivering unparalleled sound. These 5.25-inch speakers will make for great factory replacements and are available in a 4-ohm impedance.
www.skaraudio.com
