hardmen said:mellymelsr said:My vote would go for the M70. If you get the strap then weight is not an issue. It is a great sounding box with volume to spare and has very good battery life. The Lasonic TRC 931 would be my second choice as it has decent sound, gets very loud and is incredibly light. The 20/20 is a nice box but it just doesn't get loud enough for outdoor use, although I do like the sound when listeing to it indoors.
Melvin.
Your opinion about M70 can not be considered (because you is a M70 Addicted)![]()
Cheers.
But just as heavy as the RC838.BlackMoses said:Seems to me there are a few solid options out there noticeably better then the venerable M9935K, that other Sanyo sure is a looker with those VU meters.
Reli said:But just as heavy as the RC838.BlackMoses said:Seems to me there are a few solid options out there noticeably better then the venerable M9935K, that other Sanyo sure is a looker with those VU meters.
mellymelsr said:hardmen said:mellymelsr said:My vote would go for the M70. If you get the strap then weight is not an issue. It is a great sounding box with volume to spare and has very good battery life. The Lasonic TRC 931 would be my second choice as it has decent sound, gets very loud and is incredibly light. The 20/20 is a nice box but it just doesn't get loud enough for outdoor use, although I do like the sound when listeing to it indoors.
Melvin.
Cheers.
...so very, very true...![]()
