Mine came today.
Functionality wise, it does exactly what they advertise. It sounds much better than my GPO which I will be selling and replacing with this one.
The CD player spins the disc and buffers while playing a standard audio CD. Then it stops, plays off of the buffer and then spins again to read more data. It's very interesting watching it do this while listing to your music. I am sure they do that to preserve battery power, prevent skipping and possible disc damage while being carried. To my knowledge I do not recall anyone mentioning this, so I was surprised and intrigued at the same time. I like watching the disc spin though the window.
The only issue I have with mine is, one of the beauty speaker rings has a slight scrape/flaw from the factory in the gold chrome plating. I have decided not to worry with it as no one but me would notice. My wife looked it over and gave up. I had to steer her in the direction of the defect. The reason I am not going to worry about it is because if I swapped it out,
1: I'd probably just notice something else with the swap unit that could potentially be worse and, this one functionality wise is perfect.
2: I have a plan to solve this to where it won't bother me. The plan is to open it up one day and rotate the bezel around to where the flaw is on the inside
bottom where no one will see it.
I have attached a photo of the flaw. The picture makes it look worse than it really is, but it is there.
Otherwise, I think this is going to be a decent purchase. I'm not sure how well the LCD display will like being out in the sun so I think if I take it to the beach, I will keep it in the shade to be safe.
Edit: I want to preface this edit before I get started. None of the factual information below is intended to discredit the radio or is being done in an attempt to discourage sales. What I am about to describe may only apply to my purchase and may not reflect anyone else's purchase experience. I really like this radios performance for the price. That being said, I enjoy my radio even though it did come with a blemish on the speaker ring. I understand that I could've returned it and received another but, I chose not to because I didn't consider it a deal breaker for the price and it gave me a chance to see inside for myself. This is where I want to inform folks of if you ever need or plan to take your radio apart.
The main thing is being extremely careful when removing and reinstalling the case screws. The plastic is very soft. On my radio, three out of twelve case screws were stripped from factory and the threads came out with the screws. I almost decided to abort the process of turning the speaker ring because I wanted enough screws holding to prevent rattles. So I did a test of the other screws before removing them to get an idea how many were stripped and how many weren't. I did this by lightly loosening them and then seeing if they would snug back up. Once I realized it was only three out of twelve, I proceeded with my original plan. The type of plastic they use doesn't give you that nice crack sound when you loosen them. It has a very flexible feeling. Almost like a very hard rubber. The back came off with the antenna wire needing to be removed first followed by the red and white power and blue battery connector. I then proceeded to remove the left speaker trim to rotate it 180 degrees and put the flaw at the bottom inside corner. There was a tiny surprise waiting for me when I removed the screws. The back of the speaker trim piece has a locator pin that aligns with a predrilled hole in the case. This prevents you from putting it on 180 degrees out. I looked that thing up and down, even taking consideration of the grill pattern and everything. The grill is glued and crimped through slits in the plastic like many radios and it looks the same upside down as it does right side up. After determining that there was absolutely no difference in the trim ring, I removed the locator pin and installed.
Next, I tackled the three stripped screw posts. I removed the thread that came out with the screws, from the screws themselves. I was able to carefully thread them back into the posts. Then put super glue in there to lock the threads back in place. I used a toothpick to prevent the super glue from closing up the center hole until the glue was dry. I reconnected all the necessary wiring and put the rear cover back on. Knowing how delicate the threads are on this radio I used a technique that I have always used on my radios. I insert the screw into the radio. I slowly turn the screw backwards until I feel it fall back into the stock threads. Then I slowly tighten the screw. This worked on all of the screws holding the radio case together. The stripped posts tightened up snug just like all of the others but I recommend you do not go any further. Once you feel a little resistance, stop!
It's back together and I can no longer see that blemish so I am happy. I am especially impressed with the cassette player. The speed was spot on out of the box. W/F are good enough to not really notice except on certain piano intros. The radio picks up nice. It has a decent weight to it. The bass and treble are worthy of a positive review and I like the stereo separation on this. Sometimes I have noticed that the woofers have the ability to ripple voices on bass heavy songs but not a deal breaker. I like the lighted VU meters. Nice touch.
Overall, I think I am going to be happy with this thing now.
