Bummed with the sound 777Z
Mistahkeith
Requiem Æternam
May 1, 2013
114
The Keys
Joe Man I'm Sorry Your 777Z dont sound well. Man That 777H I got from you is On Point. It Lives out side. and I use it more than any of my other boxes. I Hope you get it the way you want it.
6,321
453
The factory "subs" on that box are anything but. They just put out muddy mid-bass.
6,321
453
redbenjoe said:
my gf 1000 sounds great ...
dont have a 777 to compare ...
are these much better speakers and components than in the 777 ???
i had always thought all the big GF boxes had similar or the same type sound ?
I *heard* that the 1000 has better components and interior bracing
5,762
275
jimmyjimmy19702010 said:
Re-cap? The tone board has caps. My Hitachi TRK-9300 sounded flat with no treble until the re-cap - plenty of highs now even with piezo tweeters + nice solid bass.
James..... :-)
Excellent point James! :hooray: That explains why my 777 sounds very good to me...
Down the road we all have to re-cap them.... ouch! It is lots of work! But makes them work like new// :yes:
I've done so many cap replacements in full. If you run into issues finding caps with 3 leads I can be of help!
I can teach you how to make that ground lead. I was stuck with this issue when I did a 100% recapping on state of the art German 14 valve tube radios with autotuning. :w00t: :-D
Cpl-Chronic
2,029
31
Windsor, Ontario, CANADA
If you looked at my restoration threads, you've got all the knowledge right there......
https://boomboxery.com/forum/index.php/topic/17944-my-gf-777z-project-2-ohm-stable/
https://boomboxery.com/forum/index.php/topic/20597-my-sharp-gf-777z-project-full-output/
https://boomboxery.com/forum/index.php/topic/19847-my-2nd-gf-777z-project-m70-sizzle/
I use 2-OHM BOSE CADILLAC WOOFERS & M70 Tweeters. They all bolt up with very little modding & sound great. The 2-OHM woofers can pull 10+ watts per channel, ALL DAY LONG!!
Good luck,
Cpl
10,669
168
40
WI
I know and have seen your threads on speaker upgrades. I'm putting this on my to-do list.
k2j
1,246
West Coast
baddboybill said:
Yes I'm sure this could help with highs :yes:
Bad Boy Bill
I think your right... Not sure why i can't remember lol but I think I did my beat to dirt blockbuster years ago and yes it has crystal highs.
Cpl-Chronic
2,029
31
Part of the problem of highs in my opinion is that the 4.7uF caps used in the 777Z cross the tweeters over at 8300Hz which is too high in my opinion. Cutting that in half to 4000Hz would be a great start which needs a 10uF cap. Also, Polyester/Metal film caps are best for clear audio, especially in the critical mid-range frequencies. If you use an 8-OHM tweeter like the M70's, I use a 6,8uF CAP for a roughly 3000Hz roll-off point. Also, hi-end crossovers NEVER use electrolytics.
A 3K roll-off point sounds good & isn't too much for the tweeters as far as wattage & transients.
Cheers,
Cpl
Cpl-Chronic
2,029
31
......And here, at about half way through this video, I really turn it up & bring the camera closer for a view of the woofers hopping so watch it all the way through to see. This beast is LOUD & clean too.....
VIEW IN FULL-SCREEN & 720HD to view properly:
https://www.youtube.com/watch?v=G5Cg_kHHKJI
you can see how much travel these Sub-Woofers are getting at half-volume & the sound is quite balanced & warm for a blaster, especially the 777Z.
The reason I went for 2-OHM woofers is because 2-OHM drivers work at the top range of the AMP IC's current limits & even tho others caution against this, I believe that the SHARP flagship can take it in spades. The heatsinks, although very simple, square 'U' shaped aluminum, are huge for the size of the IC. Yes, other blasters have more efficient sinks but these are giant thick plates & the IC's don't even get warm when pumping out the juice & at normal room temperatures.
Also, the IC's have an operating range of 2-16 OHMS, includes a thermal trip in case junctions get too hot & can put out a total of 45w @ 2.4-OHMS. They are the same IC's that drive the mighty CONION C-100 & the C-100 runs 5.4 OHM woofers in a push/pull setup. This translates to about 2.4 OHMS load to each channel. :yes:
So, by using 2.3-2.5 OHM nominal loads on each channel of the 777Z, I am in fact drawing as much power out as the CONION C-100. That's why I use these speakers specifically, so that I do not have to add extra amp circuits to drive my woofers effectively. Instead, I change the electrical operating range to draw the power that is available. They sound really good too, as you might be able to see from the videos.
Cheers,
Cpl
10,669
168
40
WI
I really can't wait to put some alpine speakers in mine. Just have no extra coin to throw around right now :-(
Cpl-Chronic
2,029
31
riker1068 said:
So those alpines that have the woofer and inner speaker, is that inner like having another tweeter?
Yes, the Co-axial car speakers are in fact a woofer & tweeter in 1 speaker & the tweeter usually has a capacitor inline to cross the tweeter over in the right range....
Cpl
10,669
168
40
WI
With Jimmy's pictures for his 767 speaker upgrade I was able to get my Alpines mounted no problem.
The screws I found were just a tad long, simply filing 1/8" off the tip keeps them from poking through the front of the boombox case. Very easy to do and you don't need to hack apart the original wiring or connectors to fit these Alpines.
And the final result is to die for :drool: . Sounds and looks worlds better.
