Northerner
Yep. Done dozens of speakers with acrylic paint...never had a single problemHisrudeness said:To each his own.
Sure it does! Even better with one more layer!Hisrudeness said:Looks tip top!
It is not minute amounts and will be several milligrams. A side by side sound evaluation/listening will should show the difference to good ears.T-STER said:When you say increasing the mass, we are talking such miniscule amounts you cannot possible audibly detect a difference. A thin layer of artist paint vs a thin layer of aerosol, we are talking tiny amounts of weight there. Just my opinion.
oh crap, did i miss a step? prep as in? i wiped/got all dust off then paintedMyOhMy said:Good result.Did you prep the stains or just apply two coats of acrylic onto the cones?
no need to apologize. everyone is allowed an opinion. but as i said im not confident with a spray can, last time i used i made a huge mess, lucky it was a fancy dress costume so didnt matter. im happyBoomboxLover48 said:Sure it does! Even better with one more layer!
Those upgrades are not for audio lovers.
The ideal loudspeaker diaphragm would never flex and would exhibit perfect pistonic motion. It would be infinitely rigid, well damped(stops on a dime), and the speed of sound through the material would be
unlimited. The mass would ideally be zero and the break up mode frequency would be infinity.
If you change the mass you lose the sound quality. One cannot dance and do fast movements with a heavy butt!
Just for a compromise Better believe in ultra thin layer application with an aerosol rattle can rather than getting 'muddy sound' with brush application of w/b acrylic on PAPER substrate for the looks.![]()
I am totally against painting speakers and increasing the mass of cone paper.
Just my opinion! Please don't be offended!
My apologies in advance!
yep thats about right. happy to do to a $100 radio but when it comes to my $2500 B&Ws i would even think about it.jimmyjimmy19702010 said:I agree that increasing the mass of the speaker cone is not desirable. However, a Boombox is far from HiFi and I doubt anyone without superhuman hearing would detect the difference between the before and after sound signature.
One thing everyone will notice is the beautifull white speakers!
James....![]()
