Jwrok707 said:Congrats.............that collection of yours is something else!!!!!!!!
Keep me coming
ledmeter said:That one in Japan? It was a complete wreck and still went for 80$. With all fees and shipping, you would have had a POS for big money .
I have trouble understanding how you can know how scarce a box like this is but label one in worn condition a POS... No matter how filthy or broken, it's worth it to achieve a box like the GX in any condition and at any price
blu_fuz said:Where the fark did you find that M70?DIBS!
redbenjoe said:shortly --expect some nutcase here to call dibs
mmcodomino said:THAFUZZ said:I agree. And, I humbly submit My vote that this GX be added to the top banner of boxes on Boomboxery's page. I think this is worthy.k2j said:Can you post pics of the rear & the label for archival purposes?
See above...label has been posted
And yes, Fatdog - please add it to the rotation
I would be honored to have a box of mine in there
Blasterpunk said:mmcodomino said:THAFUZZ said:I agree. And, I humbly submit My vote that this GX be added to the top banner of boxes on Boomboxery's page. I think this is worthy.
Should i make the pics for you
ledmeter said:Just looking over my Japanese ones, I don't seem to own any which have limited tuning range? All mine go to 108, including
Crown RX-9800
Sharp 508ST &SB
Sanyo MR-X920 & Big Ben
Hitachi TRK-8600
Toshiba RT-S90
So which makes limit themselves to Japanese only range? Is it just National and Victor?
Good luck with the photo shoot! Have fun! Looking forward to seeing pics!
stereomann said:is there a way to make the tuner go to 108mhz?
Crown RX-9800
Sharp 508ST &SB
Hitachi TRK-8600
Toshiba RT-S90
Terry said:... The radio on a Japanese box won't pick up stations who's frequency is above 90Mhz. i.e Q 104FM New York.
LJV said:Terry said:... The radio on a Japanese box won't pick up stations who's frequency is above 90Mhz. i.e Q 104FM New York.
Believe it or not, but to overcome that problem, the only thing you need is a small screwdriver. In each tuner there is separate FM section. It usually looks like a small tin box with several holes on top.
Once you locate the right potentiometer (usually the one on the opposite side from the ones where the FM antenna is connected, but depending on manufacturer and configuration there could be more than one needed to be adjusted) turn on the tuner, move it to 90MHz. If your tuner has digital readout keep watching the numbers, while you gently screw the potentiometer up or down. When you see the numbers on display starting to climb even though you're not touching he tuning wheel, keep on screwing until you hit 108. That's all the work that needs to be done. You'll have the tuner that picks up from approx. 86 to 108MHz.
Same goes for tuners without digital readout. Just make sure to find out which station in your area broadcasts near 108MHz and which one is close to 86MHz. Move the scale to 90MHz mark, and than turn potentiometer. It should be on so that you can hear the stations you pick up. Once you reach the station closest to 108MHz stop, and use tuning wheel to try reaching the station closest to 86Mhz. If you get that one too, that's it. It could require some additional fine tuning but you'll have 99.99% of radio stations available.
If you're not sure and worry about your own safety, ask someone at the repair shop to do it for you. It takes more time to remove the back lid, and screw it back on, than to adjust the FM range.
