The VZ-2000 is nearly there!.
Power restored after re-soldering all the joints and changing every capacitor.
Cassette now working after changing the belts. Still a problem with slow FF & RW but I'll get back to that.
Record Player working after cleaning the main belt that had turned to a gooey mess, changing the tonearm belt and installing a new door sensor leaf switch.
Bought new needles that the guy selling them stated would work in the VZ-2000. Knew as soon as I saw them they wouldn't, practically no volume when playing the record. Put the old ones back that probably haven't played a record since the late 80s/early 90s. The old needles still sound brilliant after all those years (out of the right speakers at least, which are the only ones working at the moment).
Great sound from right side speakers, just need to get left side working and everything will be running!
I've ordered a different type of contact cleaner with better deoxidising properties, and a lubricant specifically for audio switches, which will hopefully get the speakers going if I can work that in to the switches , but at least I'm now getting somewhere. Also removed the balance slider and checked the brushes but didn't help with the speaker problem.
Well chuffed having never picked up a soldering iron in my life or been any where near a circuit board!
Just hoping I can fix the left speaker issue now with the new contact cleaner and a bit of playing with them. If that doesn't work I will teach myself how to work on the other components and check the wiring. I AM DETERMINED TO GET IT FULLY WORKING!!! Thanks for the help everyone's given to date, and to everyone who has provided really helpful info and tips in all the other threads.
