you might have a bad selector switch or a solder joint problem or a lot of oxidation buildup inside the switch or a bad component failed ic or bad cap,, any of these could be it..If you cleaned the record bar than its something a bit more technical. sometimes cleaning the selector switch or the function switch need some attention but I have seen in these pannys that some of the traces gets disconnected from the solder joint where if you looked with your eyes could not see a crack on the trace by using magnifying glasses and looking closely most of the time you can spot the disconnection Thats another possibility
