as the title says, the right channel is dead or nearly dead
1) with the balance in the middle, only hear the left channel, and by increasing the volume begins to distort
2)when move to the right channel, the volume begins to decrease until they hear anything in both channels.this happens on all inputs, radio / tape / line and phono-
3)connecting headphones is exactly the same.
4)clean all switches without getting any results.
5)I checked things. tape recorded and played in another box and heard in sterero smoothly.
connect it to another box using the output of line out and listen to 2 channel smoothly, with the same signal without distortion apparent.
when using the external speaker output, the left channel works , the right output signal does not have any signal.
for now is the little test I could do.my knowledge of electronics are close to zero!any idea or suggestion is welcome to try to check
some pictures of the interior
