Just to clarify Hemiguy, my beef pertains to the huge discrepency between it's ac and dc performance levels and not the weight. The dc performance of this model, in my opionion, is only 1/4 to 1/3 of it's ac performance. It can be used as a boombox, or it can be used as a shelf system.
However, if it's going to be used as a boombox and compared to other boomboxes that are truly portable, then it should be tested in portable configuration and that means DC powered.
Most boomboxes will show some degradation in performance from DC to AC. But I'm talking about maybe 80-90% of AC potential. This one does not perform while on DC. To compare this to, say a M90, and have it crowned king of boomblasters while testing on AC would be misleading because in my opinion, the tiger metamorphosizes into a neutered kitty when on DC.
As it stands now, I don't think I'm going to be able to make this trip. But what do you guys think? To be accurate and for a more meaningful comparo, how about having two pow wows. One conducted while on 120V AC power and another on DC power, whether it's batteries, DC adapter, or simply supplying the battery voltage by clipping on some leads from a lab power supply to the battery terminals in the compartment? I'll even volunteer to supply the power supply, which can provide anywhere from 0 to 30VDC and you can even adjust the current level?
