Ok, just got one -- Blasterpunk sent it to me, and the box was big enough for me to use as a dining table. Be forewarned. Customs will be inspecting it for missles, things like that. Too big for normal stuff!
Initial Assessment:
Great build quality -- the best I've seen in a "normal boombox"
Sound is decent -- up to 1/4 volume on Batteries.... NEW Batteries. Beyond 1/4 volume, it sound like crap. Like there's something wrong kind of crap.
Reception is mediocre with antennas retracted. Need to extend them and then, they'll sound very good.
Antennas are stainless steel, terrific quality, like a swiss watch -- hope I never need replacements.
Only takes 8-D cells. What?!? Too big/heavy of a box for only 8 cells. I figure they'll probably last all of 20 minutes.
Runs on 220V AC. No external ability to switch to 120 a/c
You need to be Arnold Swartzenegger to swing this around. It's heavy a a cinder block. No, make that two cinder blocks.
Reconfigured the M1 to run on 110v A/C instead. Must be opened up and one fuse moved, and another fuse added. I figured this out by looking at the schematic for the power supply circuit, although I could've saved myself some time had I been able to read German.
So....... Let's try this again.
AMP MUCH IMPROVED NOW. Can get it it loud enough to actually generate some bass.
Tuner is same, no improvement.
CONCLUSION:
After looking at the service manual, I figured out why it sounds like crap on batteries. The power supply has dual secondaries. 1 part is 21 volts and the other part is 52 volts! I looked and looked and looked again. No mistake. The voltage on AC is on the high side. So unless you can put like 35 D cells into the telefunken, it's not going to run at it's potential when on Batteries. OK, I've frequently said that the cheapest home audio receiver almost always sounds better than the very best boombox. In this case, the Telefunken M1 is not playing fair. With a 52v power requirement, which is what the output Darlington's require on their rails, it's essentially a home amplifier that runs, no make that limps by on 2 toes when powered with batteries @ 12volts. In fact, that is the best way to describe the sound, like when a set of batteries is on it's last legs. Of course in this case, we are talking about fresh batteries. When tethered to AC, however, it runs along fine with both feet donning Adidas. I think that any boombox on a fresh set of batteries should be able to perform at or near A/C level performance. Or else, why wouldn't it just be a home shelf system? In this case, there is no way that the Telefunken can perform to it's potential on 12 volts when it's output transistors (Darlingtons) have a rail voltage of 51.5 volts. There is just no way. In fact, while almost all boomboxes and car audio implements Audio output IC's, the Telefunken has stayed with T03 packaged transistors.
Therefore, in conclusion, it's my opinion that the Telefunken Studio M1 is a great piece of audio equipment suitable for home shelf use, and for which it's a formidable piece of gear. However, with respects to it's Boombox qualities, it's a looker but a crapper in terms of battery powered performance and even a small or mid level boombox can easily whip it's butt. On AC, it's prowess is well deserved but there are tons of battery powered boomboxes that performs well even while on batteries. Even if we set aside and ignore it's heft and weight, there is no doubt that this would NOT be a good breakdancing audio source.
IT IS NOT A BOOMBOX as it fails, in my opinion the very basic test of portability. It's probably not designed as such. My guess is that it's more of a mid-high end home audio system designed to provide limited portable sound and in Europe, space is a problem so compact is the name of the game. In our Western World, we view compact as boomboxy. In this case -- NOT. I like it -- I really do. It's just not a boombox.
Shelf system
Portable Boombox
This is a very subjective review so I can hear the M1 lovers grumbling already.
Initial Assessment:
CONCLUSION:
Shelf system
Portable Boombox
