winnipegian
What was the first indication that it worked again? Mine looks like a paperweight each time I try.
Worked fine for me. Do not leave it zipped as there is no way for the boombox to unzip it.
And you need to search around to find the right file for the right unit. There are different files for different regions.
I messed about with mine for a while until I searched and found a different file for Europe and then it worked after a bit of messing about. For example, even though it worked, nothing showed on the display. Lazy programming and development from TDK on the firmware front.
It's on Boomboxery library, here: http://www.mediafire.com/folder/gq4b62c9gjw5w/TDK
The one you want is https://www.mediafire.com/file/t76lgeym4cmuyt0/TDK_3-Speaker_%28TP6803BLK%29_Firmware_Upgrade.7z/file
That's the last firmware TDK released. The version is embedded near the end of the file: "TDK 3 VER: 2.3.7 2011-09-26 America"
The firmware update instructions are here:
TDK Boombox Firmware Upgrade Instructions
MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.www.mediafire.com
TDK released two copies of the update instructions, one in October 2011 and a revision in January 2012.
They added warnings to notes 6 and 13, stressing the importance of an empty flash drive. And your patience.
Here are the original and revised entries
This is the file properties of the one I downloaded from here:
And the file that worked on mine which I got from S2G is:
It is slightly larger in size but this second one is the one that worked fully for my system.
And this is what I followed for it to work in my case.
