Hi guys and Happy Easter everyone! I recently acquired a Sony CFD-5 for not big money because the seller (italian guy, like me) stated that both CD player and cassette deck were not working; once turned on I briefly cleaned the CD player lens, tried an original CD and the unit is actually working! However I'm having problems with the cassette deck because after having replaced all of the 3 belts (not easy...) the deck is only working in reverse mode: if you try and play the cassette in forward mode the right reel does not spin, so the autostop function engages, while in reverse mode all is working as it should, including the 180° heads rotation. I suspect that an idler gear does not move correctly on its lever and does not engage the right reel but this mechanism is as complicated as a perpetual calendar mechanical watch and taking it apart almost completely in order to try and understand what's going on scares me a bit... Have some of you guys an idea on how to solve this problem, possibly without stripping the whole unit completely? Many thanks!
