The left channel on my VZ-2000 is not responding to tape, FM, FM stereo, AM, Aux, or LW signals. when tape is not playing, id I turn up the volume I hear the "sshh" sound from both channels, but only sound comes from the right.
I did a vigorous cleaning of balance, treble, bass, and all sliders, the power switch, record switch, all the top small function switches for AM, FM, FM stereo and all.
Despite all the switch cleaning I did I still have no luck on getting audio amplified signal from the left channel.
Cassette, radio and all show activity on the LED VU meter.
Thanks to baddboybill for his advices on opening it up. He is AWESOME!
It is pretty easy to break a bottom PC board and power switch without instructions.
I am seeking your kind advices and suggestions to fix this issue. It is not a bad boombox to take it apart.
The record switch lever can be easily detached from the rear side of the top assembly to remove the cassette section. Also the top volume and tuning knobs can be easily removed by using a string slipping it under the knob to make loop to pull it out.
