Recently got this tired looking GF777, cassette play buttons stuck down with cassette inside, all speakers shot and full of grit, tape switch snapped off
Made a metal switch using my angle grinder, actually used an 8mm spanner as the donor metal.
Managed to find a pair of 15cm Sony hifi speakers in a charity shop for £3, I gave them a respray in matt black, pretty good fit, just a couple of nicks taken out with an angle grinder to fit around the plastic inside the box mounting. Unfortunately they are 6ohms but better than 8.
ordered these new from germany, 4ohms
I spent about 6 hrs the other day rebuilding the cassette mechanisms, both worked fine until i plugged it in, now the right deck is stuck again, possibly due to the motor being shot and not allowing the completion of the mechanism (you'll understand if you have worked on these) pretty clever stuff.
