I completed all the jumps and the extra loose wires. Everything has continuity. I put the entire radio back together. I can hear the motor running (Without pushing any buttons) once the power was on. The reels do not spin. Eject works. Record does not engage the wire that will pull the record bar mechanism. Maybe wiring to the motor needs work? I can see other items on the deck that have been attempted to be repaired, poorly.
so far I’ve done the following with the cassette deck:
-replaced all 3 belts
-cleaned components with alcohol and cotton swabs
-repaired the cracked circuit board and replaced/added/re-soldered jump wires and connected other detached wires.
I believe there are other issues mechanically with this deck. For example, in the next photo I have circled the rewind switch mechanism area that has been repaired and looks melted together.
Do the buttons on this model stay depressed when pushed? I believe it’s a different style of deck than the usual. Either way, when play is pressed, the head mechanism does not lift up. I can move the head mechanism upward with my hands when I had the radio opened up.
I’ve also just noticed some heat coming from the top of the radio. There is a smell coming from the hot area however it’s not a burning smell or smoke smell. I’m not sure if that is from the motor running? I can hear when the motor is running and sometimes I can stop it by spinning the reels. Not sure if the motor randomly comes back on when I’m using the FM radio function. It may because the cassette motor spins in radio function when I first turn it on. I opened the radio to check the hot area. It’s definitely the motor. The cylinder was hot to the touch.
