Hello, I'm bit stuck now with trying to add aux in to RX-5010LS. Rec/Play DIN do not work (line-out?), adding to preamp output pins the sound quality is bad with lower volume and low treble compared to radio. Only good solution with good sound is to add aux to volume knob pins but I don't like this. I want to switch radio or tape without disconnecting aux.
Second question - when the tape is playing I switch to radio - radio starts playing - then I switch to sleep position - radio is still playing - then press stop tape and radio turns off - is this normal? I tried to figure out without schematics that / sleep = off / radio = radio / tape = aux / with no luck. Easiest solution seems to press play to activate aux and put a small switch between the cassette motor to keep the noise as low as possible.
Preamp is BA328: http://www.alldatasheet.com/datasheet-pdf/pdf/35945/ROHM/BA328.html
https://goo.gl/photos/NAsBZ6PwAujsrizJA [max res]
https://goo.gl/photos/rMNi7BRMzp8qQnGV6 [max res]
https://goo.gl/photos/bMXxEXnczDxY4YLBA [max res]
