Thanks so much yammi99.Hi salmansh8,
welcome to Boomboxery. Finally you found the link
The LED mod is not that difficult, but you need some electric knowledge and soldering skills. Originally in display there are small incandescent bulbs. They take to much power to be operated in battery mode. Therefore I removed all from the PCB and replaced them by 3mm orange LED's. On backside of PCB I modified the conductive paths so, that all LED's are connected in parallel. You need to cut some paths and connect some. Finally you need a pre-resistor in series to all the LED's.
Would be at the end such a circuit (example with 3 LED's in parallel):
The value of the pre-resistor depends on supply voltage, LED parameters and number of LED's.
I searched on the SONY mainboard a point were I have a permanent voltage in POWER ON state and no voltage in POWER OFF state, all in battery mode. You see this point on my last foto above ("Display LED"). In this case it is 5V. Furthermore you need a GROUND point (- Pole). You find it also on the foto.
To these points I connected the 2-wire cable that is attached to the display light PCB.
I used in total 17 LED's, because with LED's the light was not so equal as with original bulbs.
For calculation of pre-rsistor you find an example here:
LED in parallel - calculator
I hope, this explanation helps a little bit.
If you don't want to connect all LED's in parallel, you could built it for example also like this:
I searched on the SONY mainboard a point were I have a permanent voltage in POWER ON state and no voltage in POWER OFF state, all in battery mode. You see this point on my last foto above ("Display LED"). In this case it is 5V. Furthermore you need a GROUND point (- Pole). You find it also on the foto.Hi salmansh8,
