Removing front metal faceplate
Proutpouel
19
Would anyone have a good tip as to best way of removing the whole front metal faceplate? I was thinking of just leave the front side in a hot bath tub and see if the water could be able to go behind the faceplate and unglue it. I found out its all one single piece, and this thing can be bent for life without any effort. Thank you !!
5,762
275
Heat gun would help! Be careful not to go over say 60C. Keep it around 55C and check the surface temperature with a laser thermometer while evenly heating it up. The adhesive will soften and panel should come off. Hard to know plastic deflection temperature of the plastic type used there unless we check it on an old box of the same kind. Anything over the plastic deflection temperature would distort the plastic.
Proutpouel
19
I'm writing this while in the process of taking it off. I just cant believe how the glue still hold on to this thing!! Maybe lighter fluid could help it?
5,762
275
. DON’T use lighter fluid. It will dissolve the paint and plastic.
