The discussion of 50 vs 60 hz really isn't useful here because we can't choose whether our locals use 50 or 60 hz, it is what it is, but insofar as the transformers on THIS boombox is concerned, to my knowledge, both the 61 and 70 watt rated versions spec 50/60 hz. So no difference. Even if a transformer were capable of handling more power before it overheats, the boombox must be capable of consuming higher current to be useful, and if the circuitry is the same, then the boombox's ability to consume higher current will be dictated by how much voltage it is fed. The higher the voltage, the more current can be consumed. If transformer x and transformer y both output 18v and both are capable of providing the min output necessary to power the boombox, AND but transformer y can handle more current, it STILL will make no difference because both x and y will output only what the boombox needs.
