Here's my finished 5150 after painting. I first got it from a thrift store, cassette deck not working. After a new motor (purchased with help from a member here), a couple belts, a handful of capacitors, and some paint, it works great. Always looking for better sound, I found a pair of 5W silk dome tweeters to replace the blown piezos. Also I replaced 4 sets of coupling caps with slightly higher values, just to coax a little more bass out of it, which helped a bit. The tweeters have 6.8 uF crossover caps, and the paint over the beige speaker grilles was Rustoleum Metallic Black.
