You'll find that the PC-8 is a completely different machine - the PC-8 is bigger and more powerful. The PC-9 is one speaker cabinet narrower than the PC-8.Ghettoboom767 said:Interesting,I love my PC-55's!! Yes I hooked the unit uo for a while to my JBL home speakers many years ago for a while and was very surprised in the sound I heard! These are no joke,27wpc!!
Now I have the Yamaha PC-9,how does it compare to the PC-8? Curious.
Ken is alive! he is alive!Kenpat said:Great comparo. We used to have these all the time.
I have had a bi-amped, x-bass Panny myself that I got in a trade from Norm. Selling it was a major mistake, right up there with selling my first M-70.![]()
Thanks for that info,I just missed out on a PC-8 for 45.00! Bad speakers though but I should have got it.jimmyjimmy19702010 said:You'll find that the PC-8 is a completely different machine - the PC-8 is bigger and more powerful. The PC-9 is one speaker cabinet narrower than the PC-8.
I haven't heard a PC-9 though so can't give a valid comparison with regards to sound quality.
The PC-9 sure is a looker!![]()
Here is a tip for current or prospective PC-8 owners with a unit with bad drivers - RX-DT680s speakers are a possible replacement. You will have to modify (bend) the outer lip to flatten it out for the screws to attach though. The soft, compliant surrounds of the 680 speakers is very similar to the original PC-8 drivers.Ghettoboom767 said:Thanks for that info,I just missed out on a PC-8 for 45.00! Bad speakers though but I should have got it.
I feel the PC-9 is practically a Hi-Fi with very clean powerful sound,yes there needs to be a real test against these 2!
jimmyjimmy19702010 said:I think it depends on the electrical condition of the actual box you're listening to. My PC-8 blows away all of the 680s I've heard (I've got two healthy 680s here right now to compare to). The 680 gets close but no cigar. IMHO).
I agree that the 680 feels like a lightweight in terms of build when compared with the beasty PC-8.![]()
Why is the ohm rating not just one number but rather a range? For example the low has a rating of 2.7 to 8 instead of just one number. Thanks.jimmyjimmy19702010 said:
Because the 2.7-8 ohm terminals connect to an amp that is connected to a 2.8ohm speaker (driver). The other terminals (8-16 ohm) are connected to an amp that's connected to 8 ohm tweeters so it can handle a minimum of 8 ohms or more.panabox1 said:Why is the ohm rating not just one number but rather a range? For example the low has a rating of 2.7 to 8 instead of just one number. Thanks.
That's a pretty wide range. So then replacing the woofer with a lower ohm (say) 2.7 won't overpower the amp while at the same timean 8ohm woofer won't be under powered? All from the same amp?jimmyjimmy19702010 said:Because the 2.7-8 ohm terminals connect to an amp that is connected to a 2.8ohm speaker (driver). The other terminals (8-16 ohm) are connected to an amp that's connected to 8 ohm tweeters so it can handle a minimum of 8 ohms or more.
