Hello,
I have some Philips / Magnavox / Schneider ... boombox with the famous gear of the dead, made of orange nylon that break into pieces after years.
I plan to find a cheap way to have new gear without 3D printing.
But I need some help to be sure to have the right dimensions.
For D8008 and D8304 I have 3 gear to replace :
for each 2mm axial hole
single gear :
- 19mm 36 teeth
- 22mm 41 teeth
double gear
- 23mm helical 39 teeth 20° - 6mm 14 teeth
I miss the height of the double gear.
Do you think I am correct ?
(it's not my gear, mine is wear and broken)
2.5.0.0
single gear :
- 19mm 36 teeth
- 22mm 41 teeth
double gear
2.5.0.0
