Need help with my 767
mac daddy freshness
153
Sunny California
Hey ya'll i had a couple questions that i hope some of you guys are able to answer...
1.Why doesnt my 767 power up or play when i have new batteries in? Am i supposed to switch the voltage?
2.The switch that swiches from aux to line in is stuck i dont want to force it to where it breaks anything what do i do?
Thanks i hope to get a couple helpful tips :D
89
The ac/dc micro switch that is where ac cord plugs in probably is dirty or corroded. You need to clean or possibly sand the contact switch for dc to power up. As for the line in switch it may be so corroded that its stuck in position. You may try to soak it with contact cleaner for a while then try working switch. Good luck ;-)
10,900
130
I agree with Bill. I had a problem similar to that with my M90 and cleaning the female AC plug did the trick.
