Bobby. I think yours was a special case. Most of these M70 grills are glued so tight that you could destroy the case trying to remove them.
I was able to remove mine, (when I 1st got it) without any problems and without taking apart. Maybe they were already removed, but the speakers and grilles were still dirty, so I cleaned em all upFatdog said:You will need to have the front case off and speakers removed. Then remove the four screws in the front for each grille and carefully push the grilles off. They have a tiny amount of glue to help hold them in place.Master Z said:Hey FD, how did you pop the grills off? any special technique???![]()
thats a low blow, normSuperduper said:I think the grills on one of Melly's M70's came off, but I'm pretty sure that was after his wife ran over it with the SUV.:grim:
-GZ- said:thats a low blow, normSuperduper said:I think the grills on one of Melly's M70's came off, but I'm pretty sure that was after his wife ran over it with the SUV.:grim:
I need to find another M70 just so I can see what it will look like with different colored LEDs.![]()
Superduper said:Not saying there isn't an M70 out there with glue that wasn't overdone like most, but I've probably had over a dozen M70's pass through my hands, and I have yet found one that is removable. I think the grills on one of Melly's M70's came off, but I'm pretty sure that was after his wife ran over it with the SUV.:grim:
