Just to make it clear, I didn't say he HAD to use an adhesion promoter or primer, I said he could.
I also suggested to skip that step and just use a paint that's compatible with plastic.
Some people are nervous about painting plastics and the adhesion promoter/primer was a just a suggestion.
Personally, I've used SEM paint for most of my plastic jobs and have never had a blister or peeling problem even with dashboard pieces fully exposed to the sun.
For a couple of my Hamm's beer signs, I used Behr premium spray paint after wet sanding and haven't had any adhesion problems.
They're from 1956 so I have no idea what kind of plastic those are.
That said, in well over 30 refurbs, I've touched up some front panels but have never done a whole spray job on either the front or back panels.
The discoloration to some of the back panels never really bothered me.
