The SHARP 777Z horn design is an exercise in trade-offs. The horns use a hybrid horn lens similar to the M70 horns that acoustically amplifies the center dome energy which creates an extended frequency range, while damping midrange & lower midrange frequencies.
It's hard to explain but horns are much more efficient than open faced tweeters & that makes up for the fact that the tweeters are partly covered & blocked out by the narrow horn neck. Only the dome is visible from the mouth of the horn & therefore the primary emitting surface that couples acoustically to the horn. It is inefficient, compared to a properly designed compression horn but the freq response curve for the entire horn is boosted in the treble range vs the same tweeter in a traditional open face mounting at the expense of mid & low mid ranges.
Most people don't realize the 777Z was designed to fill a room with sound, not hang off your shoulder or sit on your picnic table...If I stand about 5-10 feet back from it, the horns come alive but standing next to it, the horns sound subdued because of their narrow vertical axis & wide horizontal axis. They were meant to throw the high frequencies farther forward than traditional open faced tweeters...
That is the best I can explain it ....
Brace yourselves,
The long protracted 'Is this a horn?' debate is coming.....
