kittmaster said:I have a question, I see your using hot glue......what happens when the box is hit with direct sunlight and the glue starts to melt again?
You mean "Freddie"?BoomboxLover48 said:It is a great job done by a skilled professional like Eddie!
There is a big and hard step that I cannot do.
It is to align the voice coil. I've done that with other speakers and find it hard to do on these types.
So, I never tried to venture.....![]()
Jvc is notorious for stiff speaker surround but the reasoning behind it is to maintain linearity in the Excursion by keeping the foam stiff in other words it restricts it enough to keep the voice coil from jumping out of the gap from over Excursion.Very interesting idea to use Plasti-Dip as the material to impregnate the cloth with. Hopefully it will not stiffen over time, like some rubber-impregnated surrounds do. For example the Panasonic RX-A5 suffers from that problem. The active woofers have tar/rubber-impregnated cloth surrounds which become hard as a rock after 40 years, and bass suffers as a result. So you need to replace them.
