Left channel weaker than right
label321
97
8
Hello everyone,
i have a crown 850 i noticed that the left speaker sounds weaker then the right speaker if i play with the balance knob.
my question is what it could be i spray it with contact cleaner
Thanks!
label321
97
8
ralrein1 said:
Yes,spray the pot. With some Deoxit D5. Also the volume pot too. Hope it works out. Let know if it does.
No is het something like on the amp? what ere the options?
89
Clean all switches especially the power, function and bands. You need to do it from inside unit and work each switch back n fourth 10-20 times. With these units having top mounted switches and pots they collect lots of dirt and condensation.
label321
97
8
i did but it look like the right speaker is louder than the left is it not something else whats cause the problem?
label321
97
8
baddboybill said:
Try plugging headphones into it to test. Possibly the jack is dirty or corroded.
If i do that i noticed that in the midle you have one weird echo sound but if you turn the knob al tot the right or left it looks more normal i spray it in but nothing or is it the jack plug that u put on the normal 3,5 jack from my earplugs i dont know
sorry that m anoying i respect people here on this forum with years of experience i'm learing things :-)
and i like old electronics and stuff
89
You can try spray then plug in and pull out the plug a bunch of times. This may work but if not you might need to get in jack to clean better
