Lasonic trc931 belts sizes
=ml=
686
E-Rock (Eagle Rock, L.A.)
3rd edition :huh:
Isn't the 3rd edition the i931/iPod version which doesn't have a tape deck? I thought there were just two prior versions easily identified by their number of antennae: the MK I with two antennas, and the MK II with one antenna.
I'm new to boomboxing (is that even a word?) so I may be completely wrong.
Go!
=ml=
91
=ml= said:
3rd edition :huh:
Go!
=ml=
Also the 1st edition had dual antenna, the 2nd had both single and dual antennas available and the 3rd had only a single antenna :thumbsup:
91
=ml= said:
baddboybill said:
Thanks, filling up my cart! :-)
Saw this there too:
Belt Installation Tool
Is this tool necessary to replace belts on a box?
I haven't opened the 931, so I don't know how tight the space is inside. Probably not tight at all, but I don't want to strip the threads by opening/closing it too many times.
Go!
=ml=
Yes this tool will be handy as the top deck is tight to get too but I didnt replace mine so I am not sure of belt sizes... :-D As for lower deck it will help too but you can get to belts as soon as you remove rear cover :thumbsup:
=ml=
686
baddboybill said:
=ml= said:
Saw this there too:
Go!
=ml=
Thanks, added it to my order! :-D
I'm going to document the resto; are there others already documented somewhere? I see this but it's for a 918: viewtopic.php?f=47&t=5207
Go!
=ml=
JustCruisin
3,100
17
Midwest, USA
Glad I found this topic! Tape A works perfect in my Lasonic, and Tape B used to.. but I just pulled a belt out tonight that was broken, it's 16" long!
