I have a Lasonic TRC-931 (MKII) that works well, except for no STEREO sound while using the RADIO function. I'm not hearing any scratchy pots or switches.
1) When RADIO function is selected, with STEREO selected, i only have sound in the left channel, with very low (almost non-existent) sound in the right channel with the volume turned up, balance works.
2) When RADIO function is selected, but with MONO selected, I get sound on both left and right channels at equal volume, and balance works.
3) When the AM/FM switch is rocked back and fourth several times quickly, the FM sound becomes very distorted on the left channel when STEREO is selected. The distortion goes away when switched to MONO. (makes me think that this AM/FM selector switch may be the culprit)
4) I have perfect STEREO and 2 channel MONO sound with all other functions on the box. (tape, phono, aux)
6) When headphones are plugged in, I get the same symptoms as playing through the speakers (no stereo sound with RADIO function, all other functions have STERO sound)
7) The box also has a ground type buzz that gets louder when the volume knob, or anything metallic on the left side of the box is touched. Crazy thing is, when the A tape deck EJECT button is touched, the buzz goes away completely...(not sure if the two issues are connected or not)
I have taken all boards out, looked them over for anything obvious, and have thoroughly cleaned out all pots and switches with Deoxit D5. This did not help the issues noted above.
Any suggestions to help sort out these issues would be greatly appreciated!
