So as a tech project I bought a JVC PC-W330. It mostly works save for the tape decks. For what I can get working right now it sounds amazing. It needs new speaker cables, but thank God I have some so that will be easy. My big issue is the tape decks don't work at the moment. Both play buttons are stuck down and the doors won't open. As far as I can tell from a ton of online searching the main issue might be the two main drive belts are to old and lose thus aren't spinning the flywheels needed to run the tape deck. Thus the system is stuck in a "play" position and doesn't allow the stop/eject buttons to work right. Getting to the belts, finding them online, and replacing them so far are turning out to be or will be a massive pain in the ass. Anyone have any advice or suggestions, thanks for any help you might be able to give.
