JVC M70 Left speaker very low:
label321
Hello people,
Was playing records last night works great for 1 hour,
But after 1 houre i noticed that left speaker/channel was very weak.
Radio seems to be oké.
i im not an electronic wizz so hopefully its a simple issue.
Let me know please.
Regards Justin.
Hello people,
Let me know please.
Regards Justin.
This is a very common problem with boxes having slide switches. Probably the volume control slide switch needs service.
For the time being try to spray a little Deoxit D5 Faderlube in the left slide switch of volume control and move it back and forth to see if that helps.
If the carbon resistance strip is broken you might have to fix that issue.
label321
Witch conductive paint i read here.
And is there a way to replace those sliders?
If so a link please.
Maybe Aliexpress or some tech website i live in Europe.
Regards Justin.
Hope this helps...
I got help from Superduper and badboybill for this project when I was new here...
~Royce
label321
Is that rec slider important ?
If was thinking to switch that oone with a volume slider.
Let me know.
label321
Update:
The left volume slider seems to be defect.
I was testing the radio same problem as line in.
Maybe you can use rec slider and chane it for volume slider ?
Or is it that carbon tracks that are defect and i need the conductive paint to repair that issue ?
Let me know.
Regards Justin.
I doubt you can replace the volume slider with the record slider. I don't think so. Check the resistance of the carbon tracks and it should read 50KOhms. If there is a break it will immediately show. then you can trace on the carbon track with multimeter probe gently and find the area where the crack is.
The best option is to get it professionally serviced replacing any bad components.
Superduper used to professionally service it all and make it work like new. In that case you have to disconnect that tone board and ship it to him.
I would ask him if he got time for this job. You will be pleasantly surprised with his flawless work. He is the Master Tech here. A genius!
label321
So i dont know if he can help me with this.
I live in the netherlands europe.
What are the options desolder the slider paint it with the conductive painbts en solder it back in ?
Or replace the whole thing with a new on all of them if possible.
Where can you buy these sliders new ?
i just bought this boombox for 275,- euro on ebay.
Once you find the break on the carbon strip you can use conductive paint right at the break, don't spread the length of the fixing area on the carbon disc. If you do so that it will decease the resistance value to some extend. You can fix it that way. In that case you have to remove the slider switch from the tone board. Then open it up carefully and do the work.
Our members here will chime in and give better advise.
I am no expert here.
Reactions: label321
You can use the the internal contacts from the rec sliders to fix the volume sliders. Pull it down and should be able to make it work. You can still use the rec function at auto level control.
label321
Do you mean the fingers on the inside of the slider ?
Or the whole track and fingers ?
Or is it possible tho replace the rec slider for the volume slide.
switch the 2 i mean.
Reactions: pap
I can't remember if they are transposable like on the Sharp 9090. Inside the slide the contacts are mounted on a plastic block which is identical in both rec and vol pots. This means you have standard parts that can be swapped. Once you open the slider it will all make sense if you get that far.
fisher used similar alps sliders as well
Reactions: label321
label321
Thanks!
Hopefully i can fix those volume sliders this way.
I dont know but if i use the rec slider nothing happends i dont hear a difrence in sound.
I can maybe find a tech guy and tell him that this is a possible way to repair them.
I dont know yet.
Thanks again!
Regards Justin.
Here is some very valuable information regarding M70 sliders from @Superduper
Go to #15
~Royce
The record and volume slider resistor boards are incompatible. The resistor values are too different: 50kΩ vs 500kΩ and the tonal curves are different too.
If you are hearing any sound coming from the L speaker, then the resistor board is most likely not broken or fractured. A more probably cause is the small internal feelers are loose or detached or there's dust and debris accumulated inside the sliders. You can try faderlube from Caig, flip board upside down while flushing the sliders and see if it helps. Turning the board upside down as you do this allows the chemical to drain out. Obviously this is much easier if the board is removed from the boombox. Do not overwork it and if it does not improve, the feelers might have become detached, in which case, stop and fix it. Continued movement might grind the loose feeler into the resistor track and degrade it.
If the feelers have become detached, then you'll have to disassemble them to repair. This is a rather delicate task and once you begin, you may have to repair the volume, bass and treble sliders too, as the audio signal goes through all 3 sliders before it makes it to the amplifier.
I still repair these, but only if they are virgin unmolested sliders, as I do not repair other people's work. Generally speaking, you can only open these up once or twice before the holding tabs the secure the metal case to the resistor board breaks off, so it's important that they be done right the first time. There are limitations to what can be repaired and customer pays all shipping charges if international.
Reactions: label321
label321
Hello Superduper,
Wat wil it cost to send the toneboard and repair in total ?
I can do a banktransfer if you give me a screenshot of your bank number.
If you received the money then i can send you the board.
I live in the netherlands.
Let me know.
to
label321
So it seems that the volume works but the left speaker is not bounce link the right speaker.
And stereo jack only the right speaker works with headphones cleaning it doesnt work.
I dont know what it is.
Volume knob works you see the vu meter go left or right when you slide it.
Any ideas what is could be ?
STEREONOVA
Hello people,
Let me know please.
Regards Justin.
It's good to get some contact cleaner
