How to hook iphone up to M70?
WorldFamousKylan
4
Memphis, TN
Hey guys! I'm new here so I hope this doesn't sound like a stupid question... Can someone explain to me how I can hook my iPhone up to the boombox? What tools do I need and what input do I need to use? Thanks a lot for your help!
JustCruisin
3,100
17
Midwest, USA
mancardo
1,395
Goodyear, AZ U.S.
JustCruisin said:
If you are in the USA, WalMart sells a dual RCA to 1/8" din AUX cable for around 5 bucks.. Just plug one end into the headphone jack of your phone, and the other two ends plug into the L and R Line inputs on the side of the M70!
It will look just like this.. Or just order this!
http://www.ebay.com/itm/Dual-RCA-Cable-to-3-5mm-1-8-Inch-Mini-Stereo-Cable-1-Meter-3-3ft-/121320191251?pt=LH_DefaultDomain_0&hash=item1c3f3f3513
:thumbsup: clear as water... :thumbsup:
WorldFamousKylan
4
Memphis, TN
JustCruisin! Thanks so much brother! I appreciate you taking the time to guide me in the right direction! I'm going to head to WalMart asap! :)
6,321
453
Beware of "premium" cables, a lot of them are too f'n thick and rigid, don't bend enough, and don't give you any sound advantage anyway. It's just a boombox.
Ken
2,327
Bremerton, WA, USA
Says the gentleman with untold $ invested in boomboxes... :-P
I hear you on the cables. Gold contacts are as "premium" as I usually go. I find that when you get into the longer cables it's sometimes quicker and less expensive to make your own. Most of us I'm guessing have a lot of old RCA cables hanging around from over the years. Just a thought.
Oh, and thanks again for the eBay lead on that RCA to DIN cable you hooked me up with a while back. ;-)
10,900
130
Cameronplato said:
If you wanna be old school and leverage the cassette yet have the never ending Spotify mixtape, the this is pretty neat: https://www.amazon.com/ION-Audio-Cassette-Adapter-Bluetooth/dp/B00I3YLHAC
P.S. You can control the gain the cassette so you don’t have to get up and walk over to adjust the volume or pause the party.
Yep, there's a thread about that here:
https://boomboxery.com/forum/index.php/topic/24951-ion-bluetooth-cassette/
Much cleaner than the old style with the wire hanging out the door.
