gf 9191 humming from tape heads
geoffhartwell
246
11
52
suffolk uk
i have a gf 9191 thats humming from the tape heads, when i hold down the edit button it stops, can anyone shed any light on this prob for me , thanks
Ghettoboom767
4,307
56
I have the same problem on my 9191X-toothpick for now!
I think it's the head adjustment or dirty record funtion buttons or something else?!
Let me know if you fix yours.
Have a good one-GB. :-) :hmmm:
geoffhartwell
246
11
52
suffolk uk
well after alot of head scratching trying to sort what i thought could be a ground prob, no joy, then i thought id try the record playback switch and bingo prob sorted,
alls well that ends well,
now for the next one
most of my boxes havent be played for prob 2 years
they was all working and now i have about 10 wilth probs
what was the problem exactly???
i did not understand , im sorry.
and i would like to know in case i get the same.
really.
thank you, geoff.
regards,
john
ViennaSound
4,713
49
Vienna / Austria
Must be a problem at nearly all 9191. :hmmm:
Mine do the same... :-/
Will also try this cleaning.
Headcleaning was worthless.
Sometimes it hums on the left side, sometimes on the right... :huh:
Also suddenly the JVC 550 is doing the same.
Both were working a few weeks ago.... :'-(
It's a design issue. The heads are very sensitive to interference and must be grounded via a cable shield. In many boombox designs, the ground cable goes directly to ground. On others (like the Superscopes and some Sony's have this problem, very very common) the shield wire is not grounded immediately, rather goes through the Play-Record switch. If the play-record switch develops oxidation, a bad connection develops which is the same as an ungrounded play-record head. When left ungrounded, the cables pick up stray EMI or RFI and is amplified by the circuitry causing the hum.
