GF 7600 Static
pollikk
23
NH USA
I just happened across a great looking boombox at a local pawn shop and got all nostalgic, this has lead to a non stop three day boombox researching spree. I'm loving this forum and I was wondering (as a complete novice) how would I prevent the volume slider and power button from creating large amounts of static in the right speaker? Also, did I find a decent boombox?
91
Welcome...you will need to get some deoxit or some type of contact cleaner. You should open box up and locate switches/pots to be cleaned. Usually there is a small hole or opening that you can spray a small amount in... Then work switch or pot back and forth 20-30 times. Try not to over spray and wipe excess up. Good luck!!
pollikk
23
NH USA
Thanks so much, great to be here. :-) I'm loving the site so far, I'll be pulling it apart to clean it soon! Thanks for the tip.
