Well, here is what I got to say about using those SLA 7.0ah batteries. I know, Ira is shaking his head saying here it comes...
Me thinks that Rechargeable D cells is a far better way to go than using those gel cells. Here is why.
SLA 7.0 = 7AH battery performance
Rechargeable D cells in NiMH have 10AH's.
Good Quality Alkaline D cells have 10AH too (according to 1 website)
Therefore, performance wise, using one of those gel cells will mean a hit on run time performance, and we aren't even factoring in the operational losss of the inverter.
Secondly, SLA stands for Sealed Lead Acid. So once those batteries are spent, disposal becomes an issue. You can't just throw them in the trash. While that stands true today for almost all batteries, best buy has a bin in the front of their store for your ordinary used batteries. I don't think they will accept lead acid type batteries. Those will have to be taken to your local hazard waste disposal center.
Third, by their very nature, lead acid batteries, sealed or not, requires their charge to be maintained at or near 100% or they will self discharge and sulfate. Burgular alarms, fire alarms, exit lamps and other backup devices are the best candidates for these types of batteries. If discharged, a chemical reaction (sulfation) occurs almost immediately in the battery. Once the battery becomes fully sulfated, it's is almost impossible to restore it. There are chargers that advertise the ability to reverse this phenomenon and restore a battery but don't believe it -- I have had almost zero % success in getting sulfated batteries to hold a charge. It has to do with the chemical composition of the electrolyte solution. When charged, the plates do not sulfate. When discharged, the chemical properties of the solution allows the plates to sulfate.
Also, SLA batteries do not like to be fully discharged. NiMH and NiCAD and Lithium batteries do not have this issue. Once discharged, it can be recharged again, if done immediately. A SLA that is discharged for an extended period will most assuredly be stone dead forever. I have read that when fully discharged, SLA batteries will lose 10% of their life. I have never wanted to experimented to confirm but I suspect that this is not far from the truth. Anyone that has run their car battery down on a regular basis knows that the life is drastically shortened. NiMH and Lithium cells can be recharged 500 times. Run them all the way down -- no problem. They will come back to life.
Rechargeable D's are not cheap but they more than pay for themselves and when you are shopping for your 50th SLA battery, your D cells are still cranking out the tunes. BTW, 8 NiMH D cells can be had on the bay for around $50. That's a much more environmentally and practical solution than the $39 7.0ah battery.
